Restoration & Repair Tips Board
CARB. PROBLEM
CARL PATTON
02-06-2007 18:10:20
I HAVE A 1945 H FARMALL. I HAVE A REBUILT CARB. THE PIN KEEPS SLIDING OUT OF THE FLOAT CAUSING CARB. TO OVER-FLOW. WHAT CAN I DO TO TO SECURE THE PIN SO IT DOES NOT SLIDE OUT?
Ken B.
02-07-2007 16:21:07
 Re: CARB. PROBLEM in reply to CARL PATTON, 02-06-2007 18:10:20
I of my H's did the same thing .With side cutters I put a small dimple or crimp on the pin on both ends. Ken B
RustyFarmall
02-07-2007 12:01:10
Obviously whomever rebuilt it did not do a thorough job. It should not be your problem.
glennster
02-07-2007 09:29:13
i had same problems with a few of mine too. pin would slide out, float would stick and drip gas like crazy. if you look at the carb where the pin slides thru, one end is split, the other side is not. squeeze the split side closed a little with pliers to hold the pin in better
souNdguy
02-07-2007 07:55:37
Hm.... c clip, e clip.. mushroom it. stake it in.. add a small amount of loctite sleave retainer.. hmm..
My carb needle pins seem to seat nicly with no slop.
( ms carbs and zenith carns anyway.. )
Soundguy
