Restoration & Repair Tips Board
How to test a coil?
Gwiz
02-17-2007 15:00:04
Can someone tell me how to test an ignition coil? When the ignition switch is on, I have 12 volts to the positive side of the coil. How do I test that there is fire coming out of the top and going to the distributor? I have no fire at the plugs, but I would like to see if my coil is good before blaming the points. Thanks
James
John T
02-25-2007 17:23:40
 Re: How to test a coil? in reply to Gwiz, 02-17-2007 15:00:04
G Wiz, An ohmmeter can show if a coil is definitely BADDDDD D but cant tell you if its actually GOOD. The low voltage primary winding as measured between the lil + and - terminals should be somewhere around 1 to 4 or so ohms, depends on if 6 or 12 volt coil BUTTTTT TT if its an OPEN circuit its bad/open. The high voltage secondary winding (out the tower) should be several thousand ohms and again if its open its bad. HOWEVER even if both the priamry and secondary are continuous circuits n not open that dont necessarily measn its good cuz it can break down under operating temperature at high voltage!!!!! !!!!! i.e. if either winding is open its definitely bad, but even if it passes dont mean its good under actual high voltage and hotter operating conditions.
If you apply coil voltage across the primary lil + and -/ground terminals so the primary draws current and then you interrupt the current flow such as when the points break open, a high voltage develops at the HV terminal/tower which should arc jump a current spark across a plug gap (between HV tower and ground) or an artifical one such as a gap in the wire. You can jury rig such a coil test on the bench using a battery and a coil and jumper wires and a spark plug. The spark will be weaker since theres no condensor used but if the coil is any good at all she should still spark when current is appled then interrupted.
John T
old
02-17-2007 15:13:46
Easy way to test it is remove the wire from the points side and ground it. The remove the wire from the ignition side and turn the key on. Tkae the loose wire from the ignition and touch it to the coil and take it back off again you should have a spark from the coil wire if not you have a bad coil. I hope you understand what I'm saying here you just touch the wire on and off fast as you can to get the spark
dan hill
02-21-2007 02:13:29
 Re: How to test a coil? in reply to old, 02-17-2007 15:13:46
Problem is with this method the condenser is out of the circuit and you will get a weak spark.Heres what a Model A ford taught me over 50 years ago.Turn the distributor until the points are open.Turn on the ignition and short the points quickly with a screw driver.You should get a nice blue spark from the high tension lead of the coil to ground.I used this method to bench test a 9n distributor and found the rotor was leaking to ground.The spark will occur when the short is removed.
old
02-21-2007 08:49:44
 Re: How to test a coil? in reply to dan hill, 02-21-2007 02:13:29
Dan, your sort of correct but he asked about testing a coil and what I said will work to tell you if the coil is good or bad. Now ya it will not have the brite blue spark that way but it will test the coil and tell a person if its good
Gwiz
02-17-2007 15:43:29
I think I understand all but the part about grounding the points side. In this case, the negative side of the coil is to the points. Do I need to ground that side of the coil or just remove the wire from it? James
Gwiz
02-17-2007 15:48:32
 Re: How to test a coil? in reply to Gwiz, 02-17-2007 15:43:29
OK, I think I get it. The negative side is grounded during operation as the grounded side of the points? So I do need to ground the negative side as I perform the test.
Correct?
James
old
02-17-2007 17:59:07
 Re: How to test a coil? in reply to Gwiz, 02-17-2007 15:48:32
Yep thats a simple no high teck stuff needed test for a coil. I used it a long time ago to zap friends in school but it also works to test a coil.
