Restoration & Repair Tips Board
ford2000 milky hyd?
Britt Buffingto
02-20-2007 16:29:01
I have a ford 2000, the hyd fliud is milky and they will only raise about 1/2 way up? any help?
Michael Price
02-20-2007 20:19:49
 Re: ford2000 milky hyd? in reply to Britt Buffington, 02-20-2007 16:29:01
Dont run it to long, water raises hell with bearings.
Tod
02-20-2007 17:07:44
It sounds like you"ve got some water in your hydraulic system It sometimes comes in thru the shift boots You"ll have to drain and refill and then either replace or keep the boots covered.
phil lowe
02-20-2007 17:32:18
 Re: ford2000 milky hyd? in reply to Tod, 02-20-2007 17:07:44
Correct me if I'm wrong (I'm sure you will )but isn't the hydraulic sump in the rear end and this is seperate from the trany compartment? either way you gotta drain the rear end and fill it with good fluid..
