Restoration & Repair Tips Board
ford 8N
combsdon
02-22-2007 20:14:03
I had a difficult time getting into a gear and when it did it seemed to "lock" into gear and I only had 2nd gear and could not find nuetral.....and ideas what happened?
old art
03-01-2007 20:32:24
 Re: ford 8N in reply to combsdon, 02-22-2007 20:14:03
take the top offthe trans. and see if the lever is out of position if it is push it into nutral look to see if the leveris worn off at the tip if it is find a diffrent one or weld it up make bigger ..if it has a steel knob it is a 47 later ones had a plastic knob the levera are both the same,
Stumpalump
02-24-2007 15:07:09
Post this on the 8n board on this site and you will get plenty of great help.
