Restoration & Repair Tips Board
14 hp Kohler engine will not fire
Jim Dotson
02-26-2007 13:36:12
I have a 14hp Kohler engine(model #K-321-S)that will not fire. I had to replace the switch and I think I may have rewired it wrong because it has not fired since.I have replaced the trigger switch and the coil, but it still will not fire. I would appreciate any advice from anyone.
430WLPG
03-03-2007 18:12:12
 Re: 14 hp Kohler engine will not fire in reply to Jim Dotson, 02-26-2007 13:36:12
I ran into a Kohler engine on a compressor that wouldn't fire ,so figured the coil was bad,put on new coil same thing no fire,did everything would not fire a lick, talked to the kohler people and one old guy said that he had found out one time by accident that if the coil is installed backwards it won't fire so I tried flipping it over and she fired, So apparently the coil went bad and someone took it off and went to town for a new one and returned and didn't pay any attenion how it came off and put it on backwards.
Bob
03-03-2007 22:47:29
 Re: 14 hp Kohler engine will not fire in reply to 430WLPG, 03-03-2007 18:12:12
Since he says he replaced the "trigger" that indicates it is an electronic ignition.
The electronic ignition coil has only ONE primary terminal ruling out the possibility of connecting it up backwards.
JD Ga
02-27-2007 15:42:38
Hey Pop, Have you checked the Stator yet?
JD Ga
02-27-2007 15:42:33
Bob
02-26-2007 19:52:34
Read the post below:
Link
mark from the fort
02-26-2007 19:33:47
IF you do not get many replies, try pasting it on the "garden tractor" discussion forum located under the miscellaneous header at the bottom of the discussion forum list. Mark
