Restoration & Repair Tips Board
Elyctrolysis question
GeneMO
03-02-2007 07:57:32
I have read posts on here and also searched on the web, so I have the basics down I think.
My question is that I was thinking about using a section of an old cattle panel for the metal grid.
Will it work or hurt anything because of the galvanizing on the panel? I could probably find a section where the galvanizing had rusted off.
Any other tips would be appreciated.
Thanks, Gene
JayWalt
04-12-2007 18:10:31
 Re: Elyctrolysis question in reply to GeneMO, 03-02-2007 07:57:32
i read that using galvanized steel is not recommended as it introduces zinc into the solution. Also, if u use stainless, the end result solution is considered hazardous and must be left to evaporate and the sediment disposed of properly
MPK
03-03-2007 07:12:36
A piece of flat sheet metal should work better.
GeneMO
03-02-2007 08:46:12
I see I spelled this wrong. Should be electrolysis I think.. Oh well, I think I got the point across.
Gene
banjo
03-03-2007 00:32:05
 Re: Elyctrolysis question in reply to GeneMO, 03-02-2007 08:46:12
It will probably not hurt anything but you need more surface metal to get it to work good. You will also have to clean the crud off and that might be a pain with that many angles. I would try to find something besides galvanized.
