Restoration & Repair Tips Board
Re: I'm screwed now...
deere old fool
03-05-2007 07:43:12
It might have been that you got the wrong style of extractor for the job. Using a little heat all around the part you want to get out is always adviseable. I'm trying to figure out how Rusty Farmall has ever removed a stud or bolt that broke flush, without using an extractor of some kind!
RustyFarmall
03-05-2007 08:21:42
 Re: I'm screwed now... in reply to deere old fool, 03-05-2007 07:43:12
I weld a nut to the top. Even if the stud is broken off slightly below the surface, it can still be done. If the bolt is in a recessed area where you just cannot weld, then I drill it out and re-tap the threads. Much easier to just drill it out than it is to try and remove that broken EZ-out.
