Restoration & Repair Tips Board
Ford 4000; 1972
crackersanders
03-10-2007 10:06:42
My tach.rpm gauge has not worked since I purchased. I ordered and received the two tach. cables and installed. Still does not work and gauge appears to be runing in reverse. Is there a missing part that I need to change the rotation from the small cable located in the resavor to the larger cable to the gauge?
souNdguy
03-13-2007 12:03:50
 Re: Ford 4000; 1972 in reply to crackersanders, 03-10-2007 10:06:42
I think ya got the wrong tach.
Is yours running from a genny drive, or from an engine mount drive?
Does your cluster read from right to left?
Soundguy
crackersanders
03-17-2007 18:47:15
 Re: Ford 4000; 1972 in reply to souNdguy, 03-13-2007 12:03:50
Seems to be the stock tach. The cable is to the engine drive not from a genny, although this 4000 was converted to an alternator set up. The tach. reads from right to left. Thanks for any advice.
soundguy
03-18-2007 18:39:58
 Re: Ford 4000; 1972 in reply to crackersanders, 03-17-2007 18:47:15
The post by ford farmer seems to fill in the needed info.. the aux tach drive under the oil filter is backwards of the one ont he genny.. thus a new style cluster is needed to match.. etc.
soundguy
crackersanders
03-19-2007 16:08:05
 Re: Ford 4000; 1972 in reply to soundguy, 03-18-2007 18:39:58
Sounds like that is right! I will have to figure out how to reverse the drive some how.
souNdguy
03-20-2007 05:01:15
 Re: Ford 4000; 1972 in reply to crackersanders, 03-19-2007 16:08:05
I'm pretty sure there is another cluster available.
soundguy
soundguy
03-17-2007 22:28:06
I wonder if the eng drive is backwards from the tach drive??
soundguy
crackersanders
03-19-2007 16:11:53
 Re: Ford 4000; 1972 in reply to soundguy, 03-17-2007 22:28:06
Like I said this particular tractor had the original gen. removed and an alt. put onto it. The tach. gauge is original and turns clock-wise but the small cable in the drive below the oil filter snapped into. Must have snapped when the conversion from gen. to alternator happed. What is a guy to do now....sure would like to watch a tach. when working it.
souNdguy
03-20-2007 05:06:17
 Re: Ford 4000; 1972 in reply to crackersanders, 03-19-2007 16:11:53
The answer seems simple...Either get the alternator with a tach drive, a generator with the tach drive ( both with cable ) or get a new cluster and cable.
Soundguy
Fordfarmer
03-18-2007 07:06:12
My 4600 and 7600 have the tach drive below the oil fliter, and tachs that turn counter-clockwise. My 7000's tach drive is off the rear of the injection pump, and the tach is clockwise. My 3000 has a genny-driven tach, and the tach is clockwise (as was the 5000 that I no longer have). All these are original, Ford tachs.
