Restoration & Repair Tips Board
HYDRAULIC PUMP REMOVAL FROM MF-135
STEVEN WALLACE
03-20-2007 08:18:00
MY MANUAL SAID TO REMOVE SEAT,COVER ANDLIFT ARMS. THEN IT SAID TO REMOVE COUPLING(MAIN DRIVE AND PTO. REMOVE SIDE DOWS AND THEN LIFT PUMP OUT. MYPUMP WILL NOT COME OUT. GEAR ON FRONT OF PUMP IS HITTING H/L GEAR SHIFT PIECE. I DID NOT SPLIT TRACTOR BECAUSE IT SAID I DID NOT HAVE TOO. TRACTOR IS A 1966 MF-135 PERKINS DISEILWITH MULITPOWER. CAN I REMOVE PINION GEAR TO REMOVE PUMP. THANKS FOR HELP.
