Restoration & Repair Tips Board
CAT D2 STUCK IN GEAR
bpames
03-20-2007 17:53:41
I'VE GOT A J SERIES D2 STUCK IN 2ND GEAR, I HAVE PULLED THE TOP PLATE OFF AND SPRAYED EVERY KIND OF LUBRICANT ON IT, PRYED ON IT WITH A BAR. IT WONT BUDGE. ANY SUGGESTIONS WOULD BE GREATLY APPRECIATED. THANKS
Shovelman
04-15-2007 05:04:32
 Re: CAT D2 STUCK IN GEAR in reply to bpames, 03-20-2007 17:53:41
I think WR is on the right track. Check the shifter interlock.
W R
04-15-2007 03:12:18
Check that the gearshift lock is releasing.
hector gemme
03-21-2007 03:54:44
did you try to turne some gears with the master cluch desangaged.
GeneMO
03-20-2007 20:47:10
I was just tickled to see a post about a D-2. Mine is 5U5179, not sure what year that is. Bad thing is that I dont have a clue on how to help you. I do have a parts book and a service book and owners manual if you need any copies.
Gene gene_painter@afbisinc.com
PS I am generally on the Farmall board
