Restoration & Repair Tips Board
4400 Ind Steering problem
Small farm
03-21-2007 10:22:40
I am loosing power steering fluid as fast as I can add it. In viewing past posts it seems I"ll need to remove the hood, radiator, an inspection plate??, and in this case first, a loader. What do any of you expect I will find? I do see what I"m guessing is the result of the leak but can not see the amount I have added twice since owning the tractor. Manual mode sucks with this beast and the loader is not helping. The reservoir shows the oil foaming some but can not see the leak around the pump or lins leading to the front of the tractor. The steering works ok when it"s full but it"s short lived.
