Restoration & Repair Tips Board
Case VAC gear oil leak
Cary Kennedy
03-25-2007 19:30:16
I have a slow steady leak between seal and left rear axel. Drips all over rim. How does that seal come out for repair? It appears to be counter sunk about 3/4 inch within the tractor case. No apparent way to extract seal? Any suggestions.Thanks,Cary
Rick Simmons
03-29-2007 10:38:58
 Re: Case VAC gear oil leak in reply to Cary Kennedy, 03-25-2007 19:30:16
I don't know if you have a manuel or not, if not you really need one. It will show you how it is done.
