Restoration & Repair Tips Board
Case 210B Where do you fill gear oil?
Karen Ann
03-29-2007 13:10:00
I checked the gear oil, and I know
140 weight, is best? per one man,
another even said transmission fluid?
wow, anyway, the place that I found the
stick, and checked it, isent that also
the place to fill it? (under the seat,
hex shaped big bolt)thanks so.
bradley martin
04-01-2007 16:41:44
 Re: Case 210B Where do you fill gear oil? in reply to Karen Ann, 03-29-2007 13:10:00
It sounds, Karen Ann, as if either your clutch is wore out and/or the real seal in the engine is leaking oil into the clutch housing,wetting it and causing it to slip. You should have it looked after ASAP. Repairing either or both requires "splitting the tractor"and you would be wise to repair both while it is apart.
Joe (Wa)
03-30-2007 17:23:44
Karen, 140 is too high viscosty for that transmission, perhaps they meant 85-140? Some people use that. Factory oil was 90, 80-90 is suitable also. Fill at the dipstick plug opening. Full is the mark on the dipstick about 1" from the end.
Joe
Eldo case
03-30-2007 07:42:06
Yes that is the place for gear oil. Hyd oil is checked under the steering wheel on the right side on top. Their should be a square head plug with a dipstick on it. The oil should be uhtf in it.
Karen Ann
03-31-2007 23:22:20
 Re: Case 210B Where do you fill gear oil? in reply to Eldo case, 03-30-2007 07:42:06
Thank you so for the response,
but at the end of your response
you wrote about the hydrolic oil fill,
the oil should be "uhtf" what does that mean?
Also if you know about Case 210b
my tractor after aobut 30 minutes of use,
in 1st gear, or also 2nd ( the 2 gears i use
most) it gets very slow, to move, after I take
my foot off the clutch, and as i use it more,
it seems to get slower and slower, and barely
moves at all. so i shut her off for the day.
Is my old 'Casey" just getting old?
thank you so.
Karen ann
Karen Ann
03-31-2007 23:17:43
