Restoration & Repair Tips Board
engine seized in my ferguson tef20
Dave O'Connor
03-29-2007 18:19:03
hi
the engine on my tef20 is seized, iv taken of the injectors and sprayed diesel in but no luck at all, anybody got any ideas i could try out.
cheers. dave
Bernie Bays
04-16-2007 19:59:28
 Re: engine seized in my ferguson tef20 in reply to Dave O'Connor, 03-29-2007 18:19:03
If all else fails put some classic COKE in each cylender that will take rust out in 12 hr or less
CAUTION I only use this on engines I am tearing down don"t know what the syrup will do to the bearings
Yes the Coke soft drink!
mike a. tenn.
03-30-2007 04:33:30
you didn't give much info. are you sure the engine is locked up or is the starter in a bind?
Dave O'Connor
03-30-2007 06:21:47
 Re: engine seized in my ferguson tef20 in reply to mike a. tenn., 03-30-2007 04:33:30
sorry for the lack of info, the starter is fine i took it off and looked it over,i.v changed the oil also, the tractor has been sitting for about 10 years without it being started or even touched, i,v tried to turn it over with the crank handle but no movement at all,
cheers again, dave
old
03-30-2007 07:36:04
 Re: engine seized in my ferguson tef20 in reply to Dave O'Connor, 03-30-2007 06:21:47
If it sat that long then blow that diesel out of the cylinders with air then fill them with tranny fluid. Let it sit a week or so then use the starter and a good stron battery, with the injectors out do short fast hit with the starter. If its going to pop loose it will then but if it doesn't you will probably have to open it up. I get old tractors all the time that are locked up and use tranny fluid all the time to get one loose and so far I'm 10-1 only one didn't pop loose for me and it took my 12 ton press to get one piston out of the sleeve that did pop loose
mike a. tenn.
03-30-2007 06:54:12
dave...so you're sayin' that tractor hasn't turned over in 10 years? sounds t'me like you're gonna be pullin the head and the oil pan off and soakin' it in some penetrating oil or like old said...turpentine. you could try rocking it in gear but after 10 years it might be siezed up pretty tight and you could cause more damage. i'm still suggesting that you go down and talk to some of the guys on the ferguson forum. there's a ton of experience there on the old fergies. that's where i get all my advice for my to-20 and to-35. good luck.
-mike
mike a. tenn.
03-30-2007 04:36:31
dave...try posting on the harry ferguson forum. give a good description of what you were doing when the engine siezed up, and all info like if there was oil in it, under a load, sitting for a long time, etc.? lots of guys there that can help you out.
-mike
old
03-29-2007 19:17:00
First off why is it locked up?? Did you run it low on oil or some thing else like bad seals in the injector pump getting diesel in the oil?? Also diesel fuel doesn't work well to unlock a locked up engine. My self I use either tranny fluid or turpentine, not paint thinner but true gum spirtis of turpentine.
