Sandblaster
Andrew
04-04-2002 23:56:26
Hi!
I have an air compressor, and two rusty mowers which need a decent sandblasting. Mostly it would be intermittent work, so renting one or hiring someone would be inconvenient. How much would a sandblaster cost (roughly) any idea appreciated!
James
04-10-2002 21:22:42
 Re: Sandblaster in reply to Andrew, 04-04-2002 23:56:26
I bought a pressurized sandblaster from Harbor Freight for $80.00 hood and nozzles included.
Dave_Id
04-06-2002 09:16:52
I bought just a cheap one from MSC Supply for something like $100 to $150. I see Northern has the same unit for $130. My compressor had trouble keeping up until I threw away the ceramic tips I got with it, and purchased a carbide 3/32 diameter carbide tip. I use 20/30 silica (pretty fine) to keep from plugging up. Now I have no problem keeping up. The only problem I have, which I've taken steps to remedy is moisture in the system. I have sandblasted 3 tractors with it, plus other items, and am quite satisfied with it.
gene b
04-05-2002 19:29:04
you need to know what cfm @ psi your air compressure has you need at least 25cfm at70lbs to do a decent job minium would be 10cfm at 70 with a 1/8 nozzle
Tom-Pa
04-05-2002 05:01:03
Check out the below link for Sandblast equipment.
Located in Canfield, Ohio, about 40 mi. from me..nice equipment and service.
