Restoration & Repair Tips Board
1953 John Deere 50
Clint Barnhart
04-17-2007 05:35:40
What type of motor oil, # of quarts, oil filter #, should be used. Also, what should I use in the rear end, and the volume in gallons, 80-90?
Thanks
55 50
04-17-2007 07:28:20
 Re: 1953 John Deere 50 in reply to Clint Barnhart, 04-17-2007 05:35:40
I would encourage you to get the Operator's Manual OM-R2033 and Parts Catalog PC-264 ASAP. Much good information in them. Motor oil I use is 10W-30, it holds 7 quarts. Oil filter is a JD part # AA3680R, don't know if other places carry the filter, I always buy mine at the JD dealer. Transmission and rear end is all one oil area and it uses 80W-90 with capacity of 4 gallons.
Clint Barnhart
04-17-2007 14:31:18
 Re: 1953 John Deere 50 in reply to 55 50, 04-17-2007 07:28:20
Thank for the info so far
55 50
04-18-2007 08:09:26
 Re: 1953 John Deere 50 in reply to Clint Barnhart, 04-17-2007 14:31:18
To get better results to your John Deere inquiries, you might want to put them on the John Deere part of this forum.
