Restoration & Repair Tips Board
JD g lp
Jonathon munoz
04-18-2007 17:46:06
Jd g runs good at idle and revving up. When i go up hills it pops and sputters once in awhile. The g is on lp and has new vaporizer. What should i check. It does it on vapor or liquid.
Maark
04-24-2007 17:35:12
 Re: JD g lp in reply to Jonathon munoz, 04-18-2007 17:46:06
Open the gap on the plugs. .017 is a bit close.It should run better and idle smoother at .050
jonathon munoz
04-24-2007 17:57:33
 Re: JD g lp in reply to Maark, 04-24-2007 17:35:12
I had a guy tell me that is should gap them tight .17 because the lp is already vaporized and you dont need big gap. Is .50 better for lp g's? What should we adjust tappets at for the most power? jm
Bernie Bays
04-19-2007 16:03:53
Most likely spark plugs or plug wires miss fireing under load
jonathon munoz
04-20-2007 18:42:55
 Re: JD g lp in reply to Bernie Bays, 04-19-2007 16:03:53
I put new plugs ac 386 and champions gapped at .17 and new wires and also took wires off different jd. Cap is brand new cond, rotor, points. This all happened before i did this. If i took a screwdriver and held it very close to dist. housing it would spark to the screwdriver. I grounded housing with jumper cables and no changes. Could i please get your direct email or someone that can help to contact directly. Thank you jm
