Restoration & Repair Tips Board
6V Relay retrofit?
brad_bb
04-23-2007 12:52:40
Of late I have added some accessories to vehicles which required the use of relays to activate. I am also in the process of finishing the wiring on my 55 Ford tractor which has a 6V positive ground system. I was considering whether the lighting system should be on a relay. I bought a new switch, but there"s no indication what it"s rated at. A relay would prolong it"s life. Do they make 6V relays like they do for 12V cars (spdt relay with terminals 85,86,30,87,87a)? If so, where are they available? I would think a relay may be of even greater advantage in a 6V system than a 12V. Presently I have the two headlights, instrument light, brake light, and rear worklight on the same switch. I"d like to put them on a relay. Any help appreciated.
soundguy
04-28-2007 22:53:26
 Re: 6V Relay retrofit? in reply to Brad_bb, 04-27-2007 11:44:07
Email em' and ask them what's it's contact ratings are.. then add in a 1$ inline fuse with the power feed to the switch.
Soundguy
Brad_bb
05-02-2007 10:46:04
 Re: 6V Relay retrofit? in reply to soundguy, 04-28-2007 22:53:26
I did email them and got no response.
souNdguy
05-02-2007 11:03:35
 Re: 6V Relay retrofit? in reply to Brad_bb, 05-02-2007 10:46:04
If it were mine.. and all this had transpired thus far.. I'fd be inclined to return the switch for a refund.. then hit -ANY- lovcal store like napa or autozone, or car quest, or tractor supply and get a HD fused lamp switch.. vs installing an unknown one and then watching my tractor burn one day... A lamp switch is less than 10$..
Soundguy
John T
04-24-2007 08:30:12
 Re: 6V Relay retrofit? in reply to brad_bb, 04-23-2007 12:52:40
brad, I agree a 6 volt relay oughta be easy to find but be sure n take notice of its contact ratings cuz a light wimpy one may not be rated much more then a good quality push pull switch ya know. Seems a tad overkill (use of relay) if you can instead purchase an industrial rated push pull switch of decent, maybe 15 amps or so, rating.
John T
souNdguy
04-24-2007 08:19:45
Your switch shgould show what it's contacts are rated at.. 6v headlamp switches are easy to find.
In any case.. i agree with Bob.. 6v relays are available.. even rat schack carries some. but a volkswagon parts place probably will to.
Soundugy
Bob
04-23-2007 15:43:40
The relay you describe is commonly called a "Bosch-style relay".
Check antique Volkswagen parts suppliers for a 6-Volt version.
