Restoration & Repair Tips Board
Case 320 I rear wheels
Dardan
05-02-2007 23:18:35
For all those frustrated 320 owners with broken rear wheel centers, I think I have help! The 6 bolt rear wheels seem to be prone to breaking out over the axel flange bolts. The stamping of the wheel plate is virtualy identical to the stamped steel wheel plate used on Farmall As and Bs, EXCEPT the outer 3" or so around where it bolts to the rim on the Farmall. Trim off the outer edge, carefully alighn, and weld. I was able to pick up a plate for $25- cheap good fix. And it's Case-IH!! You can also transfere your center plate into another rim, if your rim is trashed.
