Restoration & Repair Tips Board
53 golden jubilee hyd prob
Timothy Quay
05-06-2007 04:16:24
Last year my seals were weeping on my hyd pump not bad but i wanted to fix it. So i rebuilt the pump replaced it now nothing works right it won't move, hyd are not strong. I dont know what i did one thing i am woundering is i put the hyd oil for older ford tractors in it and seems to be foaming can anybody help?
53goldenjubilee
05-06-2007 15:34:53
 Re: 53 golden jubilee hyd prob in reply to Timothy Quay, 05-06-2007 04:16:24
I just recently went through the same thing. At first i replaced the o-rings under the seat still had air getting in. The second thing i did which was the fix was the 2 gaskets and o-rings up by the pump manifold. Just a suggestion.... Also try looking up old posts on these forums and look for anything written by a man named "Zane" I swear the man must have designed the tractor himself.. good luck
Tim quay
05-06-2007 16:50:26
 Re: 53 golden jubilee hyd prob in reply to 53goldenjubilee, 05-06-2007 15:34:53
did you use reg hyd or did you use the old ford tractor hyd oil? it was working before on reg hyd
53goldenjubilee
05-11-2007 04:21:23
 Re: 53 golden jubilee hyd prob in reply to Tim quay, 05-06-2007 16:50:26
I used the regular Hydraulic oil from the start. Any problems I have had have not been from the oil type.
