Restoration & Repair Tips Board
D17 ALLIS CHALMER , CLUTCH PROBLEM??
MONGO1966
05-07-2007 09:19:29
I AM A NOVICE FARMER DOING DEER FOOD PLOTS, I WAS PLOWING MY FIELD W/ A 3 BOT PLOW WHEN I LOST POWER TO THE D17. WHEN I TRIED TO RESTART TRACTOR IT FIRED UP BUT WHEN I TOOK MY FOOT OFF CLUTCH THE D17 WENT DEAD. THE TRACTOR WILL NOT ENGAGE IN ANY GEAR AND IT WONT STAY RUNNING WITHOUT KEEPING THE CLUTCH PUSHED IN. CAN ANYONE HELP ME FIGURE OUT WHAT MAY BE THE PROBLEM...BROKEN CLUTCH???, BAD TRANSMISSION??? OR IS IT SOMETHING EASY THAT I MAY BE MISSING. ANY HELP WOULD BE GREATLTY APPRECIATED.. MY TRACTOR IS IN HIBBING MINNESOTA , SO IF ANYONE KNOWS OF A RELIABLE MECHANIC OR SHOP PLEASE ADVISE, THANK YOU!!!
hectorgemme
05-08-2007 03:29:31
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to MONGO1966, 05-07-2007 09:19:29
maybe you have a broken fork I am dismantling a d17 for parts now if I can help.
mongo1966
05-08-2007 05:16:32
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to hectorgemme, 05-08-2007 03:29:31
thanks Ill keep you in mind
JMS/MN
05-07-2007 09:42:44
Sounds like something locked up in the transmission, rear end, finals, etc. Fluid levels ok? Can you move the shift lever- might be jammed in two gears? Not real close to you, but Ron 320-983-3500 (Milaca) is a good AC mechanic.
mongo1966
05-07-2007 12:00:30
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to JMS/MN, 05-07-2007 09:42:44
JMS
I AM ABLE TO MOVE SHIFT LEVER BACK AND FORTH BUT IT WILL NOT ENGAGE IN A GEAR, IF IT IS STUCK BETWEEN GEARS WHAT CAN I DO TO REMEDY THE SITUATION? THE FLUID LEVELS SEEM TO BE FINE AS EVERYTHING WAS NEWLY FILLED OR RESTORED TO PROPER LEVELS BEFORE USE.. THANKS FOR THE MECHANIC INFO. THANKS FOR YOUR INPUT JOHN R
mongo1966
05-07-2007 12:15:25
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to mongo1966, 05-07-2007 12:00:30
Is there a way to roll the tractor frontward or backward and get it to flip out of its locked position into neutral or any gear for that matter?? Or do I need to tear into the clutch to fix it?? Anyone have an experience with this type of gear lockup???
JMS/MN
05-07-2007 21:49:16
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to mongo1966, 05-07-2007 12:15:25
Simple things first. Don't rip into the clutch- that's apparently working and would require a tractor split to replace. Top of transmission is a flat plate bolted on- right? Shift lever is in that plate. Remove that and look at the gears and forks. Anything jammed, twisted? Gears should slide back and forth- neutral will let you rock tractor back and forth. If that is ok, you need to realign the forks and gears before reinstalling the cover. Do you have an I&T manual for the D17? AC-11 is for the WD, etc., D17 is another number- mine is in the shop so can't tell you the exact number now. Manual source?- check that station/farm supply store on the west side of the road that runs N/S between 169 and downtown Hibbing. Couple blocks south of 37th St. Name is something like L&M Supply?
mongo1966
05-08-2007 05:13:13
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to JMS/MN, 05-07-2007 21:49:16
I do have the manual, I will do what you suggested and look if anything is twisted or out of place under that plate, I wont be back up north for two weeks so Ill check it then and email again if I need some more advice, thanks again for your time and help.
JMS/MN
05-09-2007 11:25:18
 Re: D17 ALLIS CHALMER , CLUTCH PROBLEM?? in reply to mongo1966, 05-08-2007 05:13:13
Since it's an AC, post on the AC board for more options. Also the Tractor Board is probably read by more people than this one.
