Restoration & Repair Tips Board
Mastercraft rider stops running when in gear
Chris in NW Wis
05-13-2007 18:31:44
When I start this mower all is well while in neutral. I can even get the blades to engage while in Neutral. When I try to go forwards or backwards, the engine slows then dies.
I believe it is electrical problem because I needed to wiggle the wires behind the key switch to get it started. Once started, is fine. Except for putting it into gear and letting off the clutch/brake. Then the motor just slows down and quits. Engaging the clutch/brake quickly allows the motor to continue running.
Anyone seen this before?
souNdguy
05-15-2007 11:17:08
 Re: Mastercraft rider stops running when in gear in reply to Chris in NW Wisconsin, 05-13-2007 18:31:44
Sounds like a safety that it thinks is tripped... does it have an operator presence switch? perhaps embedde din a seat cushion.. or under the seat atop a spring loaded contact?
Soundguy
05-17-2007 17:34:30
 Re: Mastercraft rider stops running when in gear in reply to souNdguy, 05-15-2007 11:17:08
Yes it does, but its been disabled since before I got the mower.
