Restoration & Repair Tips Board
rough running 520
GLF73
05-23-2007 18:25:49
Having problems with the carb, it won"t do a steady idle, i"ve tryed float adjustment and it don"t change, I;ve noticed if i leave the bowl loose so gas leaks it will run ok, I need help PLEASE
Gene Davis (Ga.)
05-28-2007 18:28:05
 Re: rough running 520 in reply to GLF73, 05-23-2007 18:25:49
Sounds like the float/needle & seat assembly is either hanging or not shutting off fuel flow or maybe fuel level is too high in the bowl/ It is flooding.
