Restoration & Repair Tips Board
FORD 600 HYDRAULIC PRESSURE TUBE
R. G. in MS
05-27-2007 18:19:58
THE HYDRAULIC PRESSURE TUBE RUNNING THROUGH THE TRANS ON MY 600 FORD IS LEAKING. THE PART IS OBSOLETE & IT'S LEAKING ON THE BOTTOM SIDE WHERE THERE ISN'T ROOM TO BRAZE IT. HYD.& MACHINE SHOPS SAY THEY HAVE NO WAY TO SEAT HYD. TUBING TO THE TRANS CASTING TO PREVENT FLUID FROM LEAKING BETWEEN THEM. I CONSIDERED SLIDING A 3/8 TUBE THROUGH THE 1/2 & HAVING IT SILVER SOLDERED ON EACH END. ANY IDEAS? THANKS R.G.
souNdguy
05-30-2007 12:33:38
 Re: FORD 600 HYDRAULIC PRESSURE TUBE in reply to R. G. in MS, 05-27-2007 18:19:58
Do a search in the archves.. But I believe i have seen where people are tabing a metric tubing and coating it liberally with jbweld, and then cleaning the ID of the parent leaky tube.. then sliding it thru.. the OD of the metric tube and hte ID of the parent tube are apparently extremly close allowing the jb weld to get a great lasting bond.
Soundguy
R.G.inMS
06-02-2007 14:30:45
 Re: FORD 600 HYDRAULIC PRESSURE TUBE in reply to souNdguy, 05-30-2007 12:33:38
LOOKS LIKE THE 10MM WILL WORK. THANKS FOR THE HELP! R.G.in MS
