Restoration & Repair Tips Board
Case 2390 charging pump problem
Larry K.
06-13-2007 12:47:05
Hello.
I own a case 2390 tractor and I've been having problems with the Charging Pump. It's simply not working, there is no pressure and the oil isn't flowing to the filters. I changed the pump case and gears but nothing changed. I'm beginning to think it's not a pump problem.
Any ideas of what could be happening?
HTR
06-14-2007 04:52:45
 Re: Case 2390 charging pump problem in reply to Larry K., 06-13-2007 12:47:05
Is the suction screen behind the charge pump clean?
Larry K.
06-17-2007 10:57:56
 Re: Case 2390 charging pump problem in reply to HTR, 06-14-2007 04:52:45
Thanks for your answer.
I'm not sure where the suction screen is located, and I wonder if it's the same thing as the inlet filter which I can't find either.
Any sugestions?
