Restoration & Repair Tips Board
Spindle nut
Gary Halcom
06-15-2007 18:09:11
The spindle bolt that attaches the tire rod to the spindle on a 4010 John Deere, how do you do get it tight enough to take the slack out so the steering is tight.When you move the steering wheel you see the tire rod move some distance before the wheels move.
Thanks....
Dave Sherburne NY
06-15-2007 18:37:35
 Re: Spindle nut in reply to Gary Halcom, 06-15-2007 18:09:11
If the end of the tierod is loose in the steering arm put some pressure on the bottom of the tierod and tighten the nut with an impact wrench. If the steering arm is loose on the vertical spindle ask on the JD board.
