Restoration & Repair Tips Board
John Deere 60 (1955) Bad Block
Terry H
06-18-2007 15:56:47
Okay, perhaps someone can weigh in on this. Do I try to find a replacement block and pistons or should I bore and sleeve the block I have and utilize my factory pistons. The crack in the cylinder wall travels up into the ring area. I have heard mixed reactions to sleeving the block. Thank you.
Mike M
06-20-2007 05:16:13
 Re: John Deere 60 (1955) Bad Block in reply to Terry H, 06-18-2007 15:56:47
Trouble with most of those A,60 blocks is they seem to crack in the upper area of the ring travel around in a circle. When you draw up the nuts to hold the head on it will pull them open and leak again.
george md
06-18-2007 17:53:53
Terry,
There is nothing wrong with sleeving a block as long as there is a portion at the top and the bottom that is not cracked,you need about a 1/2 inch each to seal the sleeve. The whole side
of a cylinder can be missing if you install a
heavy enough sleeve. I just recently sleeved a JD A power block and bored a G block , it takes a big bar to do it.
george
