Restoration & Repair Tips Board
Coating the Mow Deck
Daryl Lembke
06-18-2007 17:40:13
I just bought my first lawn mower, a used Cub Cadet LT1525. I want to ensure a long life for my mow deck, and I have a couple sandy spots in my yard..My brother coats his with ceramic paint; And, I thought of using truck bed-liner coating..But, I see there is graphite paint out there to prevent grass from sticking; I wasn't aware this was an issue..Bed-liner would probably be bad for a sticking and clogging..But, I do plan on useing a blower after every mower..Any opinions or ideas on a good coating? Is there any problems with me using the bed liner..
thanks,
Daryl
NawlensGator
06-27-2007 11:22:06
 Re: Coating the Mow Deck in reply to Daryl Lembke, 06-18-2007 17:40:13
Duplicated a woods rm 600 mower 15 yrs ago out of 304 & 316 stainless steel and galvanized the gear box. Still looks new. Check it out:
third party image
Jerry/MT
06-27-2007 12:12:15
 Re: Coating the Mow Deck in reply to NawlensGator, 06-27-2007 11:22:06
Sure looks nice! Do you lock it up in a safe at night? Must be worth plenty!
NawlensGator
06-27-2007 12:46:43
 Re: Coating the Mow Deck in reply to Jerry/MT, 06-27-2007 12:12:15
Bought the mower new about 1980. The deck rusted out around 1990 and I paid a guy $1,000 to make a new deck out of SSt. Reused the old spindles, gearbox, and wheels. Converted it from a 5' to a 6' mower at that time (longer blades and spindles spread out more). That actually saved me a bunch of money. It works great! I keep it locked up pretty tight.
glennster
06-19-2007 19:34:07
i wouldnt use the bedliner. the deck builds up with grass and dirt, and can get pretty hard. it seals itself and the inside of the glob stays wet and rusts the deck out. the bedliner has a textured surface when it dries and that would really hold the dirt and grass. there are paints like the graphite and teflons for mower decks, that would be a better choice. clean the deck every couple of weeks to get the old grass out of there, then at the end of the season, clean the deck good, spray a light coat of oil or spray white lithium grease to help stop the rust.
Yugrotcart
06-26-2007 16:58:08
 Re: Coating the Mow Deck in reply to glennster, 06-19-2007 19:34:07
CIH makes a grahite paint. I have done several decks and if works good.
Part #547596R1
Abou $20 qt
Paul
