Restoration & Repair Tips Board
Jubilee trouble
Stephen36
06-23-2007 20:18:34
I replaced plugs and wires on tractor with 12v system. the reason was loss of power under load. The wires were arcing also. After replacing each wire I started tractor,it started just fine ran about 1 min or less and cut off. It will not start back. When i touch the coil it is hot. Could it have went bad, or what else could it be. I changed each wire 1 at a time, I also put old wires back on but still did not start. I had no issue with starting before this. Any ideas or answers would be greatly appreciated. Thanks Stephen36
jr150hp
06-24-2007 09:37:55
 Re: Jubilee trouble in reply to Stephen36, 06-23-2007 20:18:34
hey old could it be that insulator in the disribitor again ? shorting out my coil got hot when it was doing that JR.
old
06-24-2007 10:06:49
 Re: Jubilee trouble in reply to jr150hp, 06-24-2007 09:37:55
Yes it could even be that problem
soundguy
06-24-2007 07:07:44
Check fuel flow to /thru the carb
Soundguy
old
06-23-2007 21:51:07
First thing to do is pull the center wire off the cap. Hold it about 1/4 inch from the block and turn the kety on and turn the engine over> Do you have spark?? If not check the points and see if there good. If they are I'd try another coil
