Restoration & Repair Tips Board
Continental Engines
captunderdog
06-29-2007 22:13:35
I need to find a source for rebuild kits for the OHV 226ci. six cylinder. Did they use any of these in tractors? Will four cylinder parts work, like pistons, rings, etc?
God Bless
Walt
Gene Davis (Ga.)
07-01-2007 19:49:55
 Re: Continental Engines in reply to captunderdog, 06-29-2007 22:13:35
Try this guy at Montes Equipment in Chicago. E-mail is Gerard Moons montes@flash.net
They have much of the NOS Continental parts.
J Schwiebert
06-30-2007 14:48:15
Wait a minute here and I need to get my book. If you have an overhead valve 226 they were not used in ANY farm tractors,Where are you located? Some of the odd Continental OHV parts are getting a little hard to find. I know a good Continental expert in Ohio.
Inline sixes rule!
06-30-2007 13:12:44
Massey Harris 44-6 used this engine and some oliver combines used it also like the 25 and 33.
But I'm not sure if the four cylinder parts are compatible or not with your 226.
noncompos
06-30-2007 21:30:21
 Re: Continental Engines in reply to Inline sixes rule!, 06-30-2007 13:12:44
FWIW II: Gasket catalog (date unknown but guess 7-65?) shows the F226 in several Oliver combines, but lumps engine in with five other engine series: it doesn't mentiom Lhd/OHV, but I'm uncertain about the catalog terminology, to wit: it shows no valve cover gasket set for F209,218,226, but does show valve chamber cover gaskets, one for F209,218,226 and one for all EXC F209,218,226...I've always understood "valve cover" to mean on OHV, and "valve chamber" to mean the L-hd side of block opening for tappet adjustment. Maybe John will educate us...
J Schwiebert
07-01-2007 17:39:58
 Re: Continental Engines in reply to noncompos, 06-30-2007 21:30:21
Bud: I did not dig my Continental L head book out so no answers for some of this information. The FO-226 was Continental's smallest OHV 6 cylinder engine and was made as what they called A vehicle or transportation engine only as compared to the other models which were also made as industrial engines. It is a cast en block engine and takes the same pistons as the F226. So the engine will need to be bored. Bearings may be an issue as some sizes for the F-226 are leaning toward the discontinue side. That is as far as I got today. Bud all those engines you listed are L-head engines.Bud Send me an e-mail and we can discuss it this week if we don't combine wheat. Thanks. J.
noncompos
06-30-2007 19:20:00
FWIW, My 50 Motor Trk/Trctr shows the 44-6 with the F226 L-head....
