Restoration & Repair Tips Board
Case 644 tractor
Jake T.
07-01-2007 15:20:07
I just purchased a Case mod.644. It runs great. The loader works fine. The hydro seems weak.Does anyone have any input if these are adjustable or if needed rebuildable?
Thanks;
Jake T. jaket5@aol.com
wcd
07-04-2007 04:42:59
 Re: Case 644 tractor in reply to Jake T., 07-01-2007 15:20:07
I am in need of an engine driven pump for my 644, where can I find either pump or parts?
Ken Combs
07-02-2007 15:08:06
Well, first of all the Case 644 is not a Hydrostatic transmission. It has a separate engine driven pump, flow control valve and motor. Case called the hydraaulic driven.
Anyway, can you define 'weakl for us? In high range it is not intended to do any work, that is transport only. But in low range it should either pull/push whatever it is hooked to or spin the tires.
J Heitkemper
07-02-2007 10:08:29
Maybe ,,Take this ? to the ji case forum , I am sure they can help , best wishes , Jim
