Restoration & Repair Tips Board
9N 3pt problems
Chris Klein
07-02-2007 12:12:17
I have a 41 9N with 3pt problems. It seems to bounce when its fully raised. Also it seems like it is not as strong as it was. I thought it was low on fluid at first but its not. The system was working fine while using a sickle bar mower then all the sudden it started to drop as soon as the clutch was pushed in or when the pto was disengaged. Any ideas ?
Thanks
Chris
souNdguy
07-10-2007 07:32:29
 Re: 9N 3pt problems in reply to Chris Klein, 07-02-2007 12:12:17
Sure.. but first.. You'd have gotten ALOT faster response had you posted this on the N board.
in any case.. ya got a leak.. probably hyd cyl / piston.. etc.
About a 4 hr job.. and maybee 30$ in parts.. depending on how deep you get into it.. and how bad the cylinder is..
Soundguy
souNdguy
07-10-2007 07:32:22
Soundguy
