Restoration & Repair Tips Board
F510 Issue
jjjjone
07-07-2007 10:49:36
I have to jump my ignition switch and my clutch engagement switch on my John Deere F510. Have replace the ignition switch and one of two relays however still not working. Any ideas will help.
CNKS
07-07-2007 18:04:00
 Re: F510 Issue in reply to jjjjone, 07-07-2007 10:49:36
If you are saying that your PTO won't engage, replace the PTO switch. I just did that on my F525, same switches as yours. As far as the ignition switch, if you just hear a click but the starter won't engage, replace the positive battery cable. If original it gets corrosion inside the cable where you can't see it. That drove me nuts for a while. Most of the repairs turn out simple.
CNKS
07-07-2007 18:09:18
 Re: F510 Issue in reply to CNKS, 07-07-2007 18:04:00
After rereading your post, I may have misunderstood. If what you are calling the "clutch engagement switch" is actually on the right pedal, or the brake pedal, I bypassed that when I was having starting problems -- it did not help, as stated above it was the battery cable. I realized that is a safety component, I just removed it and plugged in a piece of wire. Did the same with the seat switch, may lose a foot sometime, though.
