Restoration & Repair Tips Board
1950 8N Ford
Oldarkie
07-15-2007 14:23:19
I have a 1950 8N Ford that has been converted from 6 volt to 12 volt. I have been told there is an electronic ignition that can be installed where the points and condenser are that will do away with the points and condenser. Is there anyone out there that has installed the electric ignition? If so, what are the pros and cons with this system, and how do you install it? I am not trying to make a show tractor as I use it on the farm every day. Thanks to all for any info you may have. Oldarkie
souNdguy
07-16-2007 07:33:55
 Re: 1950 8N Ford in reply to Oldarkie, 07-15-2007 14:23:19
Mnay places to get them.. probably at the parts section right here.
Pro / con?
Some of the pro's are that you don't have to worry about points corosion,,a nd cam lobe wear for the points rubbing block
Con's.. fewer for the 12v than the 6v.. except that the modules are extremly polarity sensitive... reverse the battery polarity for an instant and you let the 150$ worth of magic smoke out of it..
Soundguy
oldarkie
07-16-2007 19:39:54
 Re: 1950 8N Ford in reply to souNdguy, 07-16-2007 07:33:55
Thanks for the info soundguy. The points keep grounding out and of course the tractor won't start. Have changed the points three times along with condenser, cap, and rotor. Still won't start. It is getting 12 volts to the coil. I had made some plastic washers and finally got the thing running but in the process it has ruined the battery so I need to find out why the points keep grounding out. So far no one has been able to come up with the problem. I am open to any ideas anyone has as to why the points keep grounding out. Thanks to all for the help!! Oldarkie
soundguy
07-16-2007 20:04:19
 Re: 1950 8N Ford in reply to oldarkie, 07-16-2007 19:39:54
If this is a sidemount I'd look at the copepr strip from the feedthru insulator grommet . Also.. check the breakerplate itself... may be bad phenolic washer ( they make replacement breaker plates for this reason.
Another reason may be incorrect ponts hold down screws that are too long.. etc.
Use your ohm meter or test lamp and start pulling things apart to find the short.. etc.
Soundguy
oldarkie
07-16-2007 20:11:51
 Re: 1950 8N Ford in reply to soundguy, 07-16-2007 20:04:19
Soundguy, this is a front mount. Is there something different I should be looking for with the front mount that might be different than the side mount? Thanks, oldarkie
soundguy
07-16-2007 20:28:01
 Re: 1950 8N Ford in reply to oldarkie, 07-16-2007 20:11:51
I'd still look at the breaker plate.
Soundguy
soundguy
07-18-2007 18:32:18
 Re: 1950 8N Ford in reply to soundguy, 07-16-2007 20:28:01
While it may be a sloppy 12v conversion.. that won't have -anything- to do with your breaker shorting. Which would either have to be the breakers themselves at the pivot.. or the b-plate.. or points screw where the coil touches.. etc.
soundguy
oldarkie
07-18-2007 18:25:45
Soundguy, had the breaker plate checked and it is suppose to be ok. Finally went and talked to a guy that knows these little ford tractors from front to back. When I unloaded it off the trailer the first thing he said was that the 12 volt conversion was the worst and sloppiest job he had ever seen. He said when I get it back it will be right because he won't let it out of his shop until it is correct. Thanks for responding to my question and have a good day. Oldarkie!!
soundguy
07-18-2007 18:41:33
 Re: 1950 8N Ford in reply to oldarkie, 07-18-2007 18:25:45
soundguy
RickB
07-20-2007 17:27:33
 Re: 1950 8N Ford in reply to soundguy, 07-18-2007 18:41:33
12 volts to the coil and an eyes-on diagnosis of a sloppy conversion tells me there is a steady diet of 12 volts to the stock coil which can only handle 4 volts. This will trash breaker points almost immediately. Proper input matching to that particular coil can be an alternative to an electronic ignition conversion. Not that there is anything wrong with electronic ignition; they are perfectly fine.
soundguy
07-20-2007 21:04:43
 Re: 1950 8N Ford in reply to RickB, 07-20-2007 17:27:33
I'd look for breakers to fail 'open' rather than 'short' in an overcurrent situation.. unless they simply welded shut.. or melted the rubbing block tot he point that the cam lobes no longer produce an 'open' on rotation.
In any case.. I'd get the electrical system deloused before i switched to an e-ignition.... Don't want to compound problems.. makes them harder to troubleshoot..
soundguy
