Restoration & Repair Tips Board
Case 210B - is there transmission fluid dip stick?
Karen Ann
07-20-2007 16:15:15
Well, found a man, to check my clutch or tranny
problem, as i wrote about before. He asked where
the transmission can be adjusted (or clutch)
and if there was a transmission fluid dip stick, and where to check fluid? or does it just use
the 90w gear oil, i put under the seat?
also is this tractor have a "shuttle" system,
and details of how it worked? it is a 4 speed,
with reverse on stick shift
1959 210b with loader and blade, thanks so!!1
