Restoration & Repair Tips Board
WD stuck engine
bzerkle
07-25-2007 08:08:41
I traded for a WD that supposedly hasn't sat very long outside. When he brought it over it did have a can on the muffler and he said it ran when he parked it a a year ago. The rim rusted out so he parked it to repair it and never did get to it. Now the engine is FROZE. I mixed up some diesel,ATF, and 1/4 cup of brake fluid and dumped in the cylinders. It has sat for a week now and no luck. Any ideas before I start to tear it down?? I don't want to put in sleeves and pistons to find out the rest of the tractor is junk.
old
07-25-2007 09:36:08
 Re: WD stuck engine in reply to bzerkle, 07-25-2007 08:08:41
That mix of stuff probably will not work well at all. My self I use 100% tranny fluid and out of 20 plus engines only 2 haven't popped free. I would try to blow/wick that mix out and then fill with tranny fluid. Also if you can heat the tranny fluid up to around 150 gegrees then pout it in that helps a lot. I would also pour some down the exhaust pipe because then you know which cylinder is most likely the one that is locking up the engine because if you pull that plug out you will have tranny fluid running out of that one. BTDT way to many times
