Restoration & Repair Tips Board
Ford 800 Tractor Rear Axle oil type?
Lee Baca
07-30-2007 11:21:25
What type of oil can I use on the rear axle of my Ford 800 tractor? Can I use hydralic oil?
john_Bud
08-02-2007 13:55:51
 Re: Ford 800 Tractor Rear Axle oil type? in reply to Lee Baca, 07-30-2007 11:21:25
Don't use straight hydraulic fluid. If you want to use thin stuff, use trans/hydraulic. After 45-50 years of use, why do you want to swap to a different type of fluid?
jb
MarkB_MI
08-01-2007 03:53:04
I believe the original recommendation was 80W gear oil, but your New Holland dealer will probably tell you to use 134 universal hydraulic fluid in the rear end as well as the transmission and hydraulic reservoir. It's possible for gear oil to leak into the hydraulic reservoir (past the PTO shaft seals) and cause problems with the hydraulics.
old
07-30-2007 11:39:00
You can used HY-tran which is made for both trannys and hyds or you can use a 80W-90 or a 80W-140. I use the hy-tran because I keep it on hand all the time
