Restoration & Repair Tips Board
Zenith Carb Kit?
Bryan Poulson
07-30-2007 17:58:04
I have a 4 bolt Zenith carb, 2 5/8" opening. I'm looking for a carb kit. Any idea's where or who? Thanks Bryan
Brad_bb
08-03-2007 14:50:11
 Re: Zenith Carb Kit? in reply to Bryan Poulson, 07-30-2007 17:58:04
Surprisingly I think Napa can order kits. I believe they have a tractor catalog in their rack and it includes carb kits and floats.
tractor Hank
08-01-2007 19:06:19
I just purchased some zenith carb kits from Restoration Supply Co. 508-634-6915. I found some numbers on the carb and they were able to get me the correct kit.
slowfolk
08-01-2007 06:01:57
If it is for a particular tractor try a place that sells tractor parts for older tractors. I purchased a carb kit for a Zenith carb that was on a F20 Farmall from Rice Equipment.
noncompos
07-31-2007 09:30:10
If no one"s suggested anything better, you might try zenithfuelsystems.com or thecarburetorshop.com. Don"t know anything about either, just seen them mentioned in other posts. They"ll probably need any numbers you might find, or if nothing on carb all the measurements you can make. You might try Googling Zenith Carbs; seems like there"s a site somewhere which lists a lot of equipment that came with Zenith, but don"t recall if it also shows carb type. Good luck.
