Restoration & Repair Tips Board
D8800 engine knock
Rollo
08-06-2007 15:39:33
After sitting outside in Minnesota weather for a year-and-half, our D8800 engine now has a knock. In the previous year, the engine ran fine. Is this problem always related to mechanical failure, such as a loose wrist pin, or can it be fuel problems or otheriwse?? The engine was properly covered as well as all exhaust pipes. What might be the problem--contaminated fuel, bad injectors, or a more serious problem?? The knock seems to coming from the upper block--it's almost like 2 cylinders are not firing. The engine also vibrates a lot with increased throttle.
hectorgemme
08-06-2007 16:52:01
 Re: D8800 engine knock in reply to Rollo, 08-06-2007 15:39:33
it should be bad injector
