Restoration & Repair Tips Board
108 CUB CADET MANUAL TRANS.
STEPHEN RICHERS
08-14-2007 13:30:12
Clutch and drive shaft turn when engaged but rear wheels don't. This 108 has the creeper drive. If the rear wheels are lifted off the ground the wheels will turn but can be stopped with slight friction. Trans seem to shift ok. Any help would be of great help. Thanks
rhouston
08-14-2007 13:51:03
 Re: 108 CUB CADET MANUAL TRANS. in reply to STEPHEN RICHERS, 08-14-2007 13:30:12
there is a pin that holds a slide gear onto the creeper shift lever. It may have dropped out. If you are lucky you can remove the bottom drain plug from the creeper houseing and with the lever in the proper position push the roll pin back into position IF you are lucky, other wise you will have to remove the creeper gear and replace the pin. I have had this happen twice on my 126
rhouston
08-14-2007 14:03:56
 Re: 108 CUB CADET MANUAL TRANS. in reply to rhouston, 08-14-2007 13:51:03
one other note if you do push the roll pin back in using the drain plug hole be careful not to push it in too far. If I remember correctly if it's in too far it will interfere with the other gears.
