Restoration & Repair Tips Board
Temp/oil gauges acting funny
Albert Grindle
08-18-2007 15:05:20
Restoring a 101 combine and I let her sit inside all winter. The gauges, which worked perfectly before, are now acting up. The temperature goes to hot the instant you turn the key on and the oil is not working. Both sending units are brand new and the engine runs great so do I have a short somewhere? Thanks
David, Surrey UK
08-22-2007 06:19:47
 Re: Temp/oil gauges acting funny in reply to old, 08-18-2007 15:05:20
msb said: (quoted from post at 01:56:05 08/19/07) Check the ground to the panel where the gauges are located.
Yes, I had this with my old Land Rover. The temp gauge would hit max after a few minutes running. After doing all the usual things to the cooling system and changing the voltage regulator (which feeds the gauges with a constant voltage as the battery voltage varies), I found it was the ground connection of the instrument panel. After tightening a nut the problem disappeared and has never come back.
David
msb
08-18-2007 17:56:05
 Re: Temp/oil gauges acting funny in reply to Albert Grindle, 08-18-2007 15:05:20
