Restoration & Repair Tips Board
ford 4000
gene gonzales
08-19-2007 10:57:38
how are the cylinders number number i on the radator end ? or drivers end. what is the gap on thr points,does rotor turns clockwise, thank you
soundguy
08-20-2007 07:44:27
 Re: ford 4000 in reply to gene gonzales, 08-19-2007 10:57:38
Your manual should have a condensed service data section in it.. however you don't provide all the needed info.. like.. 3 cyl later 4000 or 4 cyl early 4000.The cyls are numbered 1 from the radiator back,.
pointsgap on the 4 cyl models is .025
I'd have to look in the manual for the 3 cyl specs..
Also.. you might have actually got more responses if you'd posted this on the ford board!!
soundguy
