Restoration & Repair Tips Board
JD3020?
Dawn Block
08-20-2007 12:29:51
How do you remove the engine hood off a JD3020 gas wide front?
JMS/MN
08-21-2007 11:12:04
 Re: JD3020? in reply to Dawn Block, 08-20-2007 12:29:51
On the underside of each rear corner, there is a 3/8 inch bolt- use a 9/16 wrench. Pull each radiator screen away from the tractor, there is a bent rod that you pull 90 degrees to the outside of the hood. Remove the gas cap, radiator cap, and air cleaner assembly. Hood should lift up past the muffler. BTDT about an hour ago- right after the wiring burned up!!!!! !!!!!
