Restoration & Repair Tips Board
Leaking cylinder sleeves
Leaky Sleeves
08-26-2007 08:22:50
My JD 410 backhoe is getting water in the oil and I think it is probably the seals at the bottom of the cylinder sleeves. Is there any stop leak that will work on a temporary basis so I can finish this project before I have to rebuild the engine?
720 in pa
08-27-2007 13:57:37
 Re: Leaking cylinder sleeves in reply to Leaky Sleeves, 08-26-2007 08:22:50
you can try stop leak but im afraid you will be dissappointed with the results.its either the orings at the bottom of the sleeves or the sleeve itself has a hole pitted through.good luck
