Restoration & Repair Tips Board
Allis Chambers Alternators
Travis A
08-31-2007 05:47:19
Need help on figuring how to wire a alternator for Allis Chambers WD... When I bought it alternator ws disconnected....wiring diagram??
Bob
08-31-2007 08:01:04
 Re: Allis Chalmers Alternators in reply to Travis A, 08-31-2007 05:47:19
Is your's a 12-Volt conversion, using an Delco alternator, or are you actually working with the original GENERATOR?
Travis A
09-02-2007 18:32:41
 Re: Allis Chalmers Alternators in reply to Bob, 08-31-2007 08:01:04
the alternator is a regular 12 volt....Don't no where to run wire from alternator to?
Bob
09-02-2007 18:45:25
 Re: Allis Chalmers Alternators in reply to Travis A, 09-02-2007 18:32:41
Here's MY photo of the BASICS of connecting up a Delco 10SI alternator:
Third Party Image
If you need MORE detail, Bob Melville, over on the Farmall Forum, has graciously posted quite a number of his diagrams for various IH's.
Pick one that is the closest to how your Allis is set up, and no one will know you used an IH diagram!
(NOTE: If using an "idiot light", simply OMIT the diode, and replace it with the "idiot lamp". Use a #194 lamp, or a lamp of equivalent current draw @ 12 Volts.)
Travis A
09-02-2007 20:08:10
 Re: Allis Chalmers Alternators in reply to Bob, 09-02-2007 18:45:25
Anyone have a wiring Diagram for Allis Chambers WD Wide Front?
