Restoration & Repair Tips Board
6 Volt Turn Flasher
Grampie Herbie
09-01-2007 18:14:30
I last Sun. I became the proud possessor of a 1925 Model T touring. Today I finished lots of TLC maintenance, including new safety glass. For the near term the only priority is the installation of Turns stop and tail lights. I have all the fixtures, but cannot seem to find a 6 volt turn flasher.
With all the experience out there with you guys, I thought some one might be able to direct me.
No I don't want to convert to 12V as the car came with a new 6V alternator. Another story.
I will not take the car on the road with out good lights and good glass. Grand daughters are worth to much.
Thank you in advance.
Grampie Herbie
Grampie Herbie
09-11-2007 07:57:08
 Re: 6 Volt Turn Flasher in reply to Grampie Herbie, 09-01-2007 18:14:30
Thank you gentlemen. You sure know allot more about this than I. I tried NAPA, Auto Zone, Advance, O'Rielly, and even J C Whitney. Not a single 6v flasher to be found. Finally my son in law found a part time one man operation. B&B Custom Circuits,
77 County Route 519, Newton, New Jersey 07860
He had exactly what I needed. Perhaps this will help someone else. Thank you again.
jdemaris
09-05-2007 14:10:09
Have you tried using a "heavy duty" 12 volt flasher? All a flasher is, is a circuit breaker made to trip at a certain amperage - regardless if 6 volts or 12 volts. They are usually fitted to match the exact load the lights draw on a specific vehicle - so - if one goes out - the flasher stops tripping. A HD flasher is supposed to be designed to trip at at even rate regardless of amperage - but I can't say I've tried one on any 6 volt light circuits.
Seems even a standard 12 volt flasher would work - but since a 6 volt light draws more amps than its 12 volt equivalent - the 12 volt standard flasher would probably blink too fast.
soundguy
09-04-2007 08:26:03
Nap../ get a flasher for a VW bug ( 6v)
I have used 6v hazard flashers for a vw n my 6v tractors.. etc.
if you can't find 6v r/l turn signals.. simply use 2 6v hazard vw flashers.. and do the wiring.. etc.. though you can do it with 1, depending ont he turn signal switch setup.. pretty easy mod..
Soundguy
old
09-01-2007 19:09:04
Any good parts store should be able to get you one BTDT just in the last few weeks on my sons motorcycle. He now has working signals on it and I just had the auto parts store order me one
