Restoration & Repair Tips Board
Primer life
DCM
09-04-2007 19:48:01
How long can primer be left on a vehicle,shedded, before paint would not adhere? Are there any problems leaving it like that.Dan
B-maniac
09-06-2007 18:59:56
 Re: Primer life in reply to DCM, 09-04-2007 19:48:01
Depends completely on the type primer it is. Some will actually absorb moisture from the air and rust within 6 mos. Others you could leave unpainted for years in a shed and never have an issue. Need to know exactly what it is to tell you which you have.
DCM
09-07-2007 05:57:46
 Re: Primer life in reply to B-maniac, 09-06-2007 18:59:56
Thr primer is a Dupont product,the application was over a year ago,so far its all primer,no rust. Dan
B-maniac
09-14-2007 19:33:38
 Re: Primer life in reply to DCM, 09-07-2007 05:57:46
Sounds like you may be safe . Just keep an eye on it for minute rust. When and if you want to paint it , sand a small spot down to metal and see if it is rusting underneath or letting loose from the metal. If not you are good to go.
