Restoration & Repair Tips Board
Ford brush hog problem
john859
09-14-2007 07:07:59
Hi! Newbie here.
I just got a Ford 8N tractor with a Ford 22-47 brush hog. I was using it on the fields yesterday and the brush hog started acting up.
I tried to tighten the slip clutch but the nut on the mower side of the clutch won't tighten.
Any suggestions? This is my first tractor.
Thanks,
John
glennster
09-14-2007 10:28:21
 Re: Ford brush hog problem in reply to john859, 09-14-2007 07:07:59
first thing to check is under the deck to see if something is wrapped up in the blades. could be you got some barbed wire fence or something in there. next i would disconect the pto shaft from the tractor and spin the shaft by hand to see if it turns the mower freely. could have a problem in the gearbox. if everything looks good, you may need to disassemble the clutch unit on the mower and clean it all up. could be rust and corrosion is holding it open causing the slippage.
john859
09-17-2007 16:59:24
 Re: Ford brush hog problem in reply to glennster, 09-14-2007 10:28:21
Thanks, Glennster!
I pulled it apart and sure enough there was plenty of rust and corrosion! I wire brushed everything good and it is working fine now.
Thanks so much for your advice. It is very much appreciated!
John
