Restoration & Repair Tips Board
Clutch on my H won't work
Steve Huggenber
09-23-2007 20:53:44
I had an axle seal leak on my H and lost a lot of fluid. Now that the seal has been replaced, the clutch doesn't seem to work. It worked fine before. I added more tranny oil but it doesn't seem to make a difference. Any ideas?
glennster
09-25-2007 11:39:51
 Re: Clutch on my H won't work in reply to Steve Huggenberger, 09-23-2007 20:53:44
sometimes the clutch will stick if it sets a while. you can try blocking the clutch pedal down with a block of wood for a few days, it should release. you can also block the pedal down, remove the starter and spray brake cleaner on the clutch. oooor... point the tractor to a big open area, hold the clutch down, start the tractor in 3rd or 4th and hold the clutch down. tap the brakes as the tractor is moving, it should release.
