Restoration & Repair Tips Board
Questions
Dick L
10-03-2007 13:18:09
Did you put the sleeves down in the block by hand and turn them by hand 360 degrees without the O rings?
That is the only way you can know if you are ready to put O rings on the sleeves. If you put them in and they do not slip all the way down you will have to remove enough metal to do so. If you can do the above then you have the wrong O rings.
I have had several say I did not do that and I didnt have a leak. So what people pass going up a hill every day that dont have a head on crash but it still dont make it the correct thing to do.
